Stecker Rückleuchten
#2 What do you want, the housing or the inserts?
Nobody knows who was the suplier of this parts when new, it is possible that there were different suplier to Reinzhagen the manufacturer of the cable trees. This part is now only available from an old damaged cable tree where this part ist still usable. -
#4 OK, but you need a special tool, looks like a half opened Cylinder, a Cylinder with a slit to pull the old inserts out. Otherwise you will damage both, the housing and the insert. I remember I once wrote with a person working at Delphi, a supplier of Connectors for automotive and I think I remember that Delphi was the supplier for this inserts.
I searched deep in my E mails and here it is:The whole plug is namend: F 7-1.
Housing: DPN 12131308 CONNECTOR BK Supplier: Delphi
Contacts:
DPN 10775447 CUZN-SN 0.75 - 1.50mm² SOCKET 1.6
25704.123.178 LEAR (Grote & Hartmann)
DPN 15324357 CUZN-SN 0.35 - 0.50mm² SOCKET 1.6
25703.123.178 LEAR (Grote & Hartmann)I remembered that in 2010 it was already not possible to get a new housing for this plug, but as I said maybe from an old cable tree.
