Kadett Boardcomputer....
  • #21
    Den schwarzen Rahmen machen wir doch grade klar :) muss nur noch rausfinden was det Kostet bis nach England zu verschicken.
    Gimme your adress @ Addz
  • #22
    Um es zu machen, reinigen Sie: ich habe schon den eigentlichen bordcomputer:
    Im wollen, den Kunststoff zu kaufen, umgibt das hält den bordcomputer in Position in zwischen den 2 Lüftenbelüftungsschlitzen:
    KadettESau: lassen Sie das umgeben? Bin ich richtig, dass Sie 15 Euros für es wollen? Und dann hat Porto zum Vereinigten Königreich hinzugefügt? Ich soll PN Sie meine Adresse.
    Mischa: Did your friend have the part im after?
    Danke, Addz.
    ------------------------------------------ Auf Englisch ---------------------------------
    To make it clear:
    I already have the actual bordcomputer:
    Im wanting to purchase the plastic surround that hold the bordcomputer in position in between the 2 air vents:
    KadettESau: Do you have the surround? Am i correct that you want 15 Euros for it? And then postage to the UK added? I shall PN you my address. :D
    Cheers, Addz.
  • #23
    @addz
    my BC works but not correctly. Its from a Astra GTE like yours ;) I bought it from Ebay.
    The Monza BC can also make problems. I belive that you can´t adjust the BC. But there are the correct codes: http://www.kadett-forum.de/jgs…ntrags_id=4&katid=10&sid=
    but i don´t know whether it can help you. Its in german ;)
  • #24
    Okay I always show in my rooms and I`ve found it, but...... its out of order.
    How ever has destroy it with my Senator breaks.
    The Plastik is broken and not okay.
    Sorry Addz.
    Iàm very angry abaout this.
  • #25
    Kiwikeks: As far as im aware, no UK GTE's came with bordcomputers? Are you sure yours is from an Astra GTE and not a UK Monza? Where did you get it from?
    KadettESau: Is it broken badly? Can it not be fixed? Is it the front of it thats broken? Thank you for looking!
    :D
  • #26
    Yes its Always Broken The Gigital glases and The plastik is Broken in trhee parts.
    and a lot of little parts.
    Its Terrible plastik.
    It´s exploding not breaking :D
  • #27
    Could you not change the plastic surround from the Monza to build it in your GTE?
    The person who had sold the BC to me, said that it is from an Astra GTE. But really it could be a lie. I don´t know!
    Einmal editiert, zuletzt von Kiwikeks ()
  • #29
    goldi: der hat nen BC der brauch keinen. Und bei classicparts von Opel haben die keinen Rahmen dafür mehr, hab da schonmal nachgefragt gehabt. Aber diesen Rahmen sucht er, mehr nich
