beauty beast
#12 maybe little more info:
installation of the engine control will be from c20xe (with ECU)
that's Motronic 2.8 with DIS - ignition maps in this engine is better than c20ne, in my opinion my engine will be more dynamic and have more power than standard steering
one little problem: the hall's sensor in c20xe, but i have one devil's conception... i hope that will be working...I intend to increase the transit of air to the engine, because the old MAF having the fold causes less air movement, a new type of circular allows for more
c20xe therefore control - beyond the burning explosion sensor, which will not head lower combustion reason explosion ignition (i don't know how this write in english - sorry for errors
I intend to work on the head 1mm lower for higher compression ratio and to raise the engine power
maybe some part from c20seh... -
#17 new year, new changes...
c20ne is a history - now will be c20xe
i was bought 2 engines in good prices, so without stupid ideas i was mounted one of them
all is new or like new - head... new vavle guides, new valve sealants, valves was grinding, bypass oil channel (head KS700), everything...
every gasket is new, screws is new - ARP2000, forged pistons MAHLE...here are photo gallery in 2009 year
http://blekota.elsat.net.pl/album/2009/index.html
best regards
ArKos -
