Hello everyone,
I did a quick search but could not find a definitive answer. I am planning to use Kadett E / Daewoo fuel tank with internal pump so I don't have all the fuss with ext pump, mountings etc. But I am a bit worried that the tank would be really close to rear axle, and tank straps as well. The short question would be - does it clear the axle when mounted? Getting the correct straps, strap supports etc. is not a problem at all, I am worried only about the whole compact-ness of this area. Is it ok or not?
