OPEL KADETT D 1.3 SR
    Better use brake calipers from the Astra MK3 If you want ro keep the small brakes. Rotors you can keep, but you have to change brake pads.
    Or you gönne use brakes from the Kadett GSi 256mm.
    You need calipers, Rotors and pads.
    And so you only can use 14 Inch rims.
    What I did on my 1.3 (60 ps) which had the solid discs front and the small drums rear (20,64 mm brake master cylinder and 178 mm servo unit) was upgrading the front system to 236x20 ventilated discs with 48 mm calipers from corsa b/astra f/vectra a and using the Servo unit from the gte model (203 mm). This was a huge improvement comparing to the original system both in terms of efficiency and of brake feeling.
